    marlborough's Avatar
    marlborough Guest
    resetting a DAIKIN RY140KUY1
    Could someone please advise me on how to reset this unit. there is an error code "UR" appering
    Aug 2009
    Dartford
    88
    Re: resetting a DAIKIN RY140KUY1
    No such daikin code as UR
    Jun 2009
    Lusk , Dublin
    1,115
    Heres a list of U codes
    U0 System Shortage of refrigerant or EEV failure
    U1 System Negative phase, Open phase
    U2 System Power supply insufficient
    U3 System Wiring check operation not executed
    U3 System Mismatch of indoor and outdoor units (Split only)
    U4 System Transmission between indoor units
    U5 System Transmission to remote controller
    U6 System Malfunction transmission outdoor to BP unit
    U7 System Transmission between outdoor units
    U7 Outdoor Malfunction between outdoor boards(RMX/RX RK)
    U8 System Transmission between master & slave R/C
    U9 System Transmission error between indoor to outdoor
    UA System Excessive number of fancoils
    UC System Address duplication of central controllers
    UE System Transmission error between indoor & central
    UF System Refrigeration system not set/wiring - piping
    UF System Terminals 1 and 3 crossed (Split/Skyair)
    UH System System error, Refrigeration system set up
    Power down outdoor unit ,power up and press and hold reset button to clear faults.
    Not advised until cause has been determined.
    Stu
    marlborough Guest
    sorry guys, the code is UA.
    My friend went and changed some of the codes ie: 10: 2.01 and I this has caused the unit to stop.
    any suggestions.
    Is there a list of standard codes which I can re input.
    Also when I change the codes how do I ensure the system takes it. As I have gone back to to what my friend have changed but shows the old code
    Apr 2006
    Torquay
    59
    130
    Hi for code 10 go to 20.2.1
    In the words of David Byrne, Well...How did I get here?
    Jan 2009
    United Kingdom
    242
    Quote Originally Posted by marlborough View Post
    any suggestions.
    Is this a split system? If so, try 11(21)-0-01, or....
    21-0-01 = PAIR (Split)
    21-0-02 = TWIN
    21-0-03 = TRIPLE
    21-0-04 = DOUBLE TWIN
  1. faceless daikin
    By quiet monkey in forum Air Conditioning
    Last Post: 27-01-2011, 11:33 AM
  2. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  3. Mitsi City Multi VS Daikin VRV
    By sumsor in forum Fundamentals
    Last Post: 14-07-2010, 05:54 PM
  4. daikin ry140kuy1 ducted LP fault
    By paul_h in forum Air Conditioning
    Last Post: 09-09-2009, 08:54 PM
  5. Fixing Daikin A3 Error
    By Stuffy in forum Air Conditioning
    Last Post: 27-03-2009, 06:02 AM
