Thread: Sporlan Expansion Valve
03-11-2010, 09:08 PM #1
Hello everyone,
This is my first post, so I hope I won't be getting too much out of the subject.
I am having trouble identifying two Sporlan expansion valves which I will be replacing with Danfoss. I have to replace with Danfoss as I have a time limit for delivering the work.
I managed to get the tonnage for both valves except for the thermostatic charges. Would anybody be able to help me with identifying the thermostatic charges C, L and Z?
It has already been 2 days and since I posted my request to Parker and still no reply.
Thank you.
03-11-2010, 10:09 PM #2
Re: Sporlan Expansion Valve
What temps are the evaporators operating at?
C Ice
03-11-2010, 10:21 PM #3
Sporlan TEV documents here, see doc 10-10 and 10-9.
EG, C charge for 50°F to -10°F
Z charge for 0°F to -40°F
http://www.sporlanonline.com/tevs.shtml
Danfoss charge data
http://www.danfoss.com/North_America...Language=en-US
Click on type T2 / TE2 614KB.Last edited by Brian_UK; 03-11-2010 at 10:34 PM.
16-11-2010, 10:21 PM #4
Here is another site http://www.sporlanonline.com/
17-11-2010, 12:38 PM #5
The L charge is temperature dependent and not so responsive to pressure change. It is intended for use in larger ammonia systems with multiple evaporators where a change in the flow through one expansion valve has almost no effect on suction pressure.
07-01-2011, 09:08 AM #6
Thanks a lot, it was for an ammonia application, but single circuit. It contained about 43 individual circuits. We had them ordered from Parker and it took about 3 months to arrive.
31-01-2011, 06:55 PM #7
Ashwin123,
Do you mind giving us the details on the Parker Tx valves for ammonia?
Happens to be that I'm looking for Tx valves to repalce old Sporlan Tx valves
Thanks, Josue
Hart Scientific 7080 Calibration bath: faulty CP expansion valve
By havertyp in forum Trouble ShootingReplies: 3Last Post: 09-05-2009, 03:17 AM -
Actual Expansion Valve Process
By AastroGuru in forum FundamentalsReplies: 11Last Post: 03-02-2009, 09:53 AM -
Setting of Hand expansion valve
By Iceehot in forum NH3Replies: 7Last Post: 10-09-2008, 01:25 AM -
the function of the electronic expansion valve
By Crystal-426 in forum FundamentalsReplies: 10Last Post: 22-06-2008, 12:29 PM -
Need Divine Intervention - plugged drier or expansion valve?
By archibaldtuttle in forum Trouble ShootingReplies: 4Last Post: 08-06-2008, 06:52 PM
