Results 1 to 50 of 130
29-01-2011, 05:50 PM #1
Re: Home made swimming pool heat pump
Some years back, a friend asked me to have alook at his fathers pool heater.
A basic set up with a condensing unit, maybe 1hp, situated within his large green house and a stainless steel cylinder with copper discharge pipework coil running through it. It looked like a home made jobby.
When I connected my gauges on the suction rotolock, water came out
When It was stripped in our workshop, the discharge copper coil was disintegrating,
I managed to replace it, dry out the existing condenser, rebuild it and re-install it back into his greenhouse. It's still going strong
I used 316 S/S tubing though, not copper in the re-build.
I haven't worked on any S & T HX's for pools since, only brazed plate HX's
29-01-2011, 05:59 PM #2
29-01-2011, 06:11 PM #3
03-02-2011, 09:51 PM #4
Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
29-01-2011, 06:23 PM #5
29-01-2011, 06:31 PM #6
I've seen this happen with copper cold water pipes that were connected to galvanized iron fittings. I went into a customers garage and there was a fine mist of water being sprayed from the numetous micro perforations in the pipe. How it hadn't burst I'll never know. The whole length was pretty much the same. Water conducts electricity.
Also, years ago my dad worked for the gas company in the UK. In the late 60's/early 70's there was a shortage of copper pipe so they decided to install central heating with steel pipe. Total disaster, it all had to be ripped out and replaced due to electrolysis destroying the steel pipe.
03-02-2011, 09:35 PM #7
I have come across many situations simillar to that you mention. We find if we test the water the PH tends to be down below 0.7. At this level the water leeches all metal components. In some cases I've had to return and redo the whole wash out within months of the first repair. One guy was an industrial chemist and thought checking his water 6 monthly would be adequate? every week is essential at the min.
I find worse case is when there are lots of children using the pool for other than swimming. Air born Chloramines rot all the metal work, stainless as well.Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
08-02-2011, 01:37 PM #8
Seeking Tips on Getting the Most from a Heat Pump
By kenelias in forum New to REReplies: 4Last Post: 29-11-2010, 08:52 PM -
Pool Heat Pump
By elvis in forum Heat PumpsReplies: 5Last Post: 23-03-2010, 09:18 PM -
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
Home designed and built heat pump!
By The MG Pony in forum Heat PumpsReplies: 15Last Post: 17-08-2007, 02:01 AM -
Heat pump made from a TM-15HD?
By The MG Pony in forum TransportReplies: 8Last Post: 18-05-2007, 07:37 PM
