Results 1 to 1 of 1
29-01-2011, 12:47 AM #1
Danfoss Thermostatic Expansion Valve
Hi !
I' m also new.
Can someno help me. I need an information about Danfoss TXV TEZ and TES. They looks the same TEZ it is written R407C and for TES is written R404A. They looks the same. I used them for several times for heat pumps (water source and grounde source). But there is no information if they work in both direcion (flow). My question is can I use them for Air source heat pump where require is defrost. I usually take or there are allready instaled Emerson BAE TXV. Those work both ways.
Thanks.
Fopa
danfoss expansion valve sizing for chiller
By ah fai in forum FundamentalsReplies: 1Last Post: 13-11-2010, 06:44 PM -
Danfoss ICAD/ICM Valve problem
By piewie in forum NH3Replies: 3Last Post: 11-09-2010, 09:20 AM -
thermostatic Expansion valve location
By dolce in forum Trouble ShootingReplies: 11Last Post: 05-07-2010, 03:26 AM -
thermostatic expansion valve
By ateeq.baig in forum CommercialReplies: 11Last Post: 03-06-2009, 05:05 PM -
thermostatic expansion valve sizing
By ank_gl in forum Air ConditioningReplies: 2Last Post: 03-03-2009, 03:22 PM
