    May 2006
    Isle of Wight, Uk
    47
    424
    williams retarder/prover
    Hello guys, have any of you guys got or have a link to a service/tech manual for a ten year old retarder prover? Model number RPC2T, serial number 0012302302. I have the operating instructions but nothing else.
    Any help much appreciated.
    Andy
    Dec 2010
    devon
    837
    Re: williams retarder/prover
    have the controller book what do you need to know
    May 2006
    Isle of Wight, Uk
    47
    424
    I have got the operating instructions for the controller, but what I need is parameter settings, wiring diagrams, exploded parts diagrams etc.
    I've never seen retarder/provers until this week - a customer of mine moved premises, during the move, smashed the condenser coil on one of his machines. And this one which has never had a problem, now trips rcd every few hours. Probably a defrost heater problem, if it has got one. Before I go In there and start ripping it to bits I'd like to be armed with some sort of info on the machine first.
    Andy
    Dec 2010
    devon
    837
    Whats it on when trip goes this unit has some serious heaters does it blow trip on heat or prove or retard they tend to go bang when the water goes in
    May 2006
    Isle of Wight, Uk
    47
    424
    I still haven't been back to it, the baker says it when compressor tries to start. He had an electrician have a quick look and has determined that the unit has a slight earth leak somewhere. He has also taken that circuit off the rcd, system holding in now. I'll do a megger test on the comp next time I'm in there. Every bit of kit he has moved to the new site has had problems since the move.
    Andy
    Dec 2010
    devon
    837
    had the same on a williams prover the condensing unit held in by small screws when unit moved the invisible fairys came in and smashed the neck off condensor ity went in switched on and ran but no lp switch so bang went the comp, those damn fairies
  1. Chinese retarder/prover
    By Andy AC in forum Commercial
    Last Post: 11-01-2011, 09:46 PM
  2. williams blast chiller electric defrost heater question
    By Contactor in forum Fundamentals
    Last Post: 18-06-2010, 07:35 PM
  3. Williams Jade
    By boulting in forum Commercial
    Last Post: 16-03-2010, 01:11 PM
  4. Williams HD2 Compressor?
    By The Penguin in forum Commercial
    Last Post: 06-05-2009, 01:11 PM
  5. Williams Website
    By Latte in forum Computers & the Internet
    Last Post: 10-12-2006, 09:27 PM
