Results 1 to 12 of 12
Thread: High Temp Compressor
05-04-2010, 01:34 AM #1
We are currently designing a heat pump to recover waste heat from a 55 C bath and pump it to a 95 C bath. We are looking at using a mixture of R152a and R245a. Which in studies has provided a good response in the 90-100C heating range. In the particular study the experiment was run using R 134a compressor. I’m wondering if anybody has any recommendations for 5-6 kW compressors that can handle discharge temps in the 100 C range.
18-05-2010, 06:17 AM #2
Re: High Temp Compressor
Hitachi products may have this type.
18-05-2010, 07:07 AM #3
04-09-2010, 03:32 AM #4
I have a Bristol 12 ton r22 unit in a similar application running r 416. Was originally R12. The Manufacturer used a smaller displacement compressor due to the high head pressures and temp's. The Kiln manufacturer also used copemetics and Carlile compressors. I have recorded discharge temps of 127C with condenser ambient of 74C. Only one Compressor replacement since 1990. One evaporator, 4 expansion valves and one distributor.
28-09-2010, 06:54 AM #5
i suggest you to use 2 stage compressor. its usually design as rotary type compressor (2 cylinder type)...
28-09-2010, 08:06 AM #6
R744 transcritical compressors can handle discharge temperatures in excess of 150°C
01-12-2010, 01:32 PM #7
01-12-2010, 03:39 PM #8
17-01-2011, 03:09 PM #9
helloooo guys,
suction pipeline is freezing most of the time & i notice thata the pressure @ low side is to low, how it is happen & whay? anyone can share the idea...
17-01-2011, 03:18 PM #10
17-01-2011, 03:20 PM #11
19-01-2011, 07:08 PM #12
sounds like restricted evap air flow, maybe plugged filter, dirty coil anything causing low air flow.
copeland scroll durability
By Third_techtrio in forum Technical DiscussionsReplies: 16Last Post: 23-01-2010, 04:47 AM -
How to Design Refrigeration Systems
By US Iceman in forum FundamentalsReplies: 63Last Post: 24-07-2008, 04:27 PM -
Compressor Pressures at High Ambient Air
By Andreas11 in forum Air ConditioningReplies: 16Last Post: 18-04-2008, 09:28 AM -
norlake walkin troubles (bad compressor?)
By flyboy3b in forum Trouble ShootingReplies: 11Last Post: 21-11-2007, 08:45 PM -
High Disc Temp
By road31 in forum IndustrialReplies: 9Last Post: 15-09-2006, 08:47 AM
