    Ashland's Avatar
    Ashland Guest
    Fujitsu inverter split A/C 50Hz and 60Hz are interchangable?
    Fujitsu inverter split systems for America and Canada are 208-230volt 60Hz (note: two hot lines) while those of Europe are 220-240 volt 50Hz (note: one hot line and one neutral). Since the compressor is designed to vary speed, could the American version work safely and efficiently with 220-240 volt 50Hz? Does the unit use the same board?
    Re: Fujitsu inverter split A/C 50Hz and 60Hz are interchangable?
    What do Fujitsu say about it?
    Ashland's Avatar
    Ashland Guest
    Actually, I have not talk to their technical department, but the nameplate says 208 -230 volt and 60 Hz.
  1. 110v 60hz fridge freezer runnin on 110v 50hz
    By helpneeded552 in forum Electrical
    Last Post: 22-02-2011, 04:16 PM
  2. 110v 60hz in a country w/ 220v 50hz
    By dkupinsky in forum Technical Speculations
    Last Post: 02-08-2010, 03:20 PM
  3. 50HZ compressor on a 60HZ circuit
    By dan wong in forum Technical Speculations
    Last Post: 13-06-2009, 05:52 PM
  4. 50Hz vs. 60Hz, okay to run at slower frequency?
    By pezagent in forum Commercial
    Last Post: 26-05-2003, 07:48 PM
