Threaded View
24-12-2010, 04:59 AM #4
Re: Appropriate thickness of rubber insulation
You will need at least 60mm to avoid condensation there,,,,,i would not think about using rubber as it will eventually fail,,,look at using polyeurethane at least 50mm thick would be a starting point if yoou want it done right.Lawrie
Acoustic Insulation for Ductwork
By titanum456 in forum IndustrialReplies: 3Last Post: 17-08-2010, 11:09 PM -
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 02:54 AM -
pipe insulation thickness
By bangoman in forum Air ConditioningReplies: 3Last Post: 24-04-2008, 08:43 PM -
Emmisivity as insulation thickness determinant ?
By sharshal in forum Technical SpeculationsReplies: 4Last Post: 23-10-2006, 02:26 AM -
reduce thickness of bended copper tubes
By rlim in forum Air ConditioningReplies: 4Last Post: 08-07-2003, 10:58 PM
