    Oct 2008
    newbury
    1,444
    Ventilation rates
    Is it ok to work on air changes per hour rather than 10l/s?
    Is this acceptable under building regs as the room I'm looking at requires 1770M3/hr yet the people rate is 8 times that.....!
    5,667
    Re: Ventilation rates
    Hi Richard
    The air change rate should be adhered to, to comply with Part F. The 10l/s/person is the fresh air requirement for each occupant.
    What this means is that your system can be recirculating to achieve the air change rates, with the fresh air amount added to this and a balancing amount discharged to atmosphere.
    Some instances require a large amount of fresh air (2000 seat bingo hall) where the total fresh air volume is sufficient to satisfy the ACH rate as well.
  1. Underground ventilation for -25°C Freezer room
    By edisonconsult in forum Commercial
    Last Post: 02-11-2010, 05:44 PM
  2. Australian award rates.
    By dogma in forum Legal-Business-Marketing
    Last Post: 10-11-2008, 05:26 AM
  3. question on ventilation rate for a/c system
    By coldkeeper1 in forum Air Conditioning
    Last Post: 12-07-2008, 02:50 AM
  4. Ventilation
    By SteveDixey in forum Air Conditioning
    Last Post: 24-09-2007, 11:40 AM
