Thread: Manifold hose-seal replacement
21-11-2010, 01:37 AM #1
Hello,
I am in a fulltime HVAC course here in Cincinnati,Oh and I recently put new seals in a set of hoses I have been using.They would leak fairly bad.I realize that I had probably tightened the hoses to tight too many times.With the new rubbers in should they sit flush or stick up past the schrader core needle?When I put them in I just push them down as far they would go and then I would screw in a new ribbed brass insert until it would bottom out as well.I would like to fix them properly before class or I would ask my instructor.Thank you all.
21-11-2010, 01:44 AM #2
Halls shaft seal replacement
By Loafa in forum Industrial CompressorsReplies: 0Last Post: 02-08-2010, 03:46 AM -
New Digi-Cool® Paradigm™ Manifold
By HVACGod in forum Tools and CalculatorsReplies: 22Last Post: 23-12-2009, 03:21 PM -
Manifold Gauge and Hose question
By lees8110 in forum Air ConditioningReplies: 20Last Post: 10-06-2009, 10:51 PM -
Frick shaft seal leaking
By Ian B in forum Industrial CompressorsReplies: 12Last Post: 27-01-2009, 10:31 PM -
Hose is too short!
By peterfoster in forum DomesticReplies: 11Last Post: 01-06-2008, 09:25 PM
