09-11-2010, 01:13 PM #1
Ice keeps building up inside the fridge section
Hi can you please help me.
I have a samsung double door fridge/freezer. On the frigde section of it, inside on a corner, ice keeps on building up, i removed all of the ice once, but within hours the ice built up again. I couldnt find the cause of it. This ice build up is on the bottom shelf, on the left hand side in a corner. Its not quite a shelf but a like a base It is not right on the bottom of the fridge but it falls on the middle of the fridge.
can anyone please help? Would be much appreciated.
09-11-2010, 07:34 PM #2
Re: Ice keeps building up inside the fridge section
It seems like you have a leaky door seal allowing moist air to ingress, or a crack in the fridge wall insulation.
09-11-2010, 07:51 PM #3
Thats sounds like a defect in the insulation injection.
Too bad.
10-11-2010, 06:05 AM #4
10-11-2010, 11:50 AM #5
Building a Beer Fridge
By Mark506 in forum Technical DiscussionsReplies: 1Last Post: 09-04-2009, 08:06 AM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Back inside wall of fridge warm to touch
By jamstu77@google in forum DomesticReplies: 3Last Post: 08-12-2007, 08:26 PM -
building a wood fired intermitent absorption fridge
By josephcrawley in forum Technical DiscussionsReplies: 4Last Post: 06-09-2007, 05:11 AM -
Building a fridge with a window ac unit
By josephcrawley in forum Technical DiscussionsReplies: 6Last Post: 04-08-2007, 02:10 PM
