Thread: samsung RL33SBNS 11.6CF
23-10-2010, 10:02 AM #1
my fridgefreezer is up the spout! the freezer works fine but the fridge dosent get that cold it was on the middle setting so i moved it to the top setting but it still only feels like its running on minimum,it is 3 years is it fixable?
23-10-2010, 10:16 AM #2
Re: samsung RL33SBNS 11.6CF
Might be a blockage of ice on evaporator,any signs of frost in the freezer?if there is empty freezer and switch off for 24 hours(cold air from freezer is blown up into fridge)to completely defrost it,could be a failed defrost heater although these usually shut down if defrost heater fails,also the nofrost sensor may be faulty.
Could also be issues with compressor or refrigerant charge.
23-10-2010, 10:22 AM #3
thanks,theres some slight frost on the freezer drawers so will try what you advised
06-11-2010, 08:29 PM #4
the fridge is now running just fine
05-08-2011, 05:59 AM #5
HI, jackeen2001 could you tell me what you did to fix your problem as i have the exact problem with the exact fridge thanks
