    3,853
    Packo milk tank system
    Heres a couple of vids of a second hand milk cooling system i installed last year.
    I did the refrigerant and chilled water pipework, the customer did the mains water pipe to the plate heat exchanger.
    The system will cool milk from cow body temperature to around 4/7C in one pass and then chill to storage temperature in the tank.
    I was called to replace a failed solenoid coil as you can see
    http://www.youtube.com/watch?v=ajPF5kOCD-Y
    and
    http://www.youtube.com/watch?v=1tIkS...eature=related
    Jon
    Nov 2006
    708
    Re: Packo milk tank system
    Some nice install there is there is it all yours (fridge side) ?
    3,853
    Quote Originally Posted by Quality View Post
    Cheers! The customer sited all the equipment and i joined it all up, pipe work and wiring, and commissioned it. I did the hot and cold water supplies to the in built cleaning system too as the plumber had too much else to do on site!
    All the stainless pipework is the parlour guys work as is the vacuum pumps and air comp in the plant room.
    It made a nice change to have a play with some bigger stuff as most of what i do is 7/8 and 1/2 pipework and this was 1 3/8 and 5/8, only trouble i had was bending the 1 3/8 as i had lost a few kgs since last time and couldn't get the stand bender to move
    Jon
    Sep 2003
    ISRAEL
    72
    4,248
    Nice work Jon, Looks good.
    3,853
    Thankyou Chemi!
    Jon
  1. Over charged system... what symptoms?
    By Clk320_Greg in forum Trouble Shooting
    Last Post: 19-10-2009, 06:25 PM
  2. vacuum reduces when vac pump is isolated
    By bill1983 in forum Fundamentals
    Last Post: 04-08-2009, 08:00 AM
  3. Enthalpy Increasing Buffer System
    By Reflexive in forum Technical Speculations
    Last Post: 23-12-2008, 03:18 PM
  4. Refrigeration system simulation and optimization
    By autt in forum System Optimization
    Last Post: 05-12-2008, 02:59 PM
  5. Automotive A/C Vent Temp Range vs System
    By Don Browney in forum Air Conditioning
    Last Post: 15-05-2002, 06:19 AM
