Results 1 to 20 of 20
Thread: Walk-in Cooler
    ajd1550's Avatar
    ajd1550 Guest
    Walk-in Cooler
    I have a walk-in cooler and just replaced the compressor. I can not get ***** to flow. The pressure will go up to 90 on the suction side and that is it. The site glass shows nothing. Could this be a dryer problem or what else would cause this?
    Re: Walk-in Cooler
    And on the discharge side ?
    90 of what?
    A few more clues as to what you have might help.
    Feb 2008
    adelaide sth.oz
    1,015
    Re: Walk-in Cooler
    replaced the compressor but not the drier it seems.good one fella
    Feb 2006
    derbyshire
    610
    Re: Walk-in Cooler
    took the rubber bung out ?
    Oct 2010
    NJ, U.S.A.
    8
    Re: Walk-in Cooler
    agree with post # 2 about provding more info ... or maybe calling someone actually qualified . . . no offense
    Oct 2003
    5,630
    Re: Walk-in Cooler
    The original poster dropped in without introducing him first and expected and answer with 1 post, even no feed-back.
    The suction goes up to 90...feet.Attach the unit firmly to the ground with big and strong bolts I should suggest.
    May 2009
    New Zealand
    Re: Walk-in Cooler
    Screw comp, Phase rotation ? Watched a tradesman do it the otherday, got called to a job I quoted because the comp wouldn't pump...
    manchester
    5,639
    Re: Walk-in Cooler
    why do people not change driers/contactors/relays-always take the cheap route and then wonders why it bites them on the a**e.
    was it pressure tested after the change as this could have proved flow though the system .
    introduce nitro through the hi side then observe the low side gauge to see it rise.-as long as the discharge valve is shut to prevent it flowing through the compressor.
    was the system vacced out if so to what and for how long.any backdrop?.is the compressor actually running.why did the previous compressor fail?
    Nov 2011
    Canada
    1
    Re: Walk-in Cooler
    So , lets have some more detailed info/background . or if the problem is solved let us know what the cause turned out to be? (unless your afraid to show your fallibility)
    Re: Walk-in Cooler
    Quote Originally Posted by madblack View Post
    With a one post wonder I wouldn't bother with any more comments.
    Jul 2010
    manchester
    212
    Re: Walk-in Cooler
    I agree with install monkey
    changing the drier and contactor is SOP
    some people put a new pot on and find out the contactor is u/s i beg to differ if the pot was u/s in the first place in some cases.
    your only as good as your last job
    tcsbill's Avatar
    tcsbill Guest
    Re: Walk-in Cooler
    ..Meanwhile in Greece...
    I'm so sorry to inform you that most time customers do'nt want to pay an extra 15-20 euros for a filter..or a nitrogen system cleaning..
    Customers always want to do the best for them..in the cheapest way though !!!
    Right then is when you try to find other ways to clean up a system for example..or find cheaper quality parts for replacing....
    3,853
    Re: Walk-in Cooler
    Compressor is on backwards hth.
    manchester
    5,639
    Re: Walk-in Cooler
    why dont u fit 2nd hand compressors just to ensure it f**ks up then,and you can be cheaper in your quotes,really keep em happy,also offer a 15minute warranty too,for peice of mind
    Quote Originally Posted by tcsbill View Post
    tcsbill's Avatar
    tcsbill Guest
    Re: Walk-in Cooler
    ok,just a different frequency of communication
    manchester
    5,639
    Re: Walk-in Cooler
    theres no logic in fitting a £130+ component and risking that the drier will be ok,and the electrics havent been damaged with handling a siezed/down to earth compressor,after youve done all the hard work,changing a pot and when u switch on and run it,it doesnt perform,then youll have to degass it to fit a drier,maybe a return visit,and it costs you more because the owner is too tight and doesnt know best, its like you ordering a kebab and finding the bread mouldy,you wouldnt accept it,and hes wasted time putting salad and meat on it,only to have to give you another kebab-they need to accept that the fridgie knows best,you dont tell him how to cook,he shouldnt tell u that he doesnt need a drier.
    Jul 2010
    manchester
    212
    Re: Walk-in Cooler
    i totally agree i wouldnt eat a mouldy kebeb well maybe depends how drunk i am !!!!!!!
    Jul 2010
    manchester
    212
    Re: Walk-in Cooler
    replacing driers, and contactors when replacing compressors is a must !!! it may not come back like a boomerang on the occassion but as many of you are aware it will and not doing this is poor workmanship.
    and fitting a compressor backwards is definatly a no no !!!!! or brazing the capillary into the suction on a compressor how on earth this guy did this i seen once i dont know he must have had a mouldy kebab and not gone straight home.
    Jul 2010
    manchester
    212
    Re: Walk-in Cooler
    and if some of you are sat there scratching your heads yes capillary into the suction directly into the danfoss compressor.
    he crimped the suction connection on the pot and f!!!n BRAZED IT.
    and to make double sure brazed the end of the suction up back from the evap.
    YES SCARY AND FU!!!!N BIZZARE what a TOOL.
    Jun 2008
    gloucester
    44
    72
    Re: Walk-in Cooler
    Thats mad mate
  1. Walk in cooler & walk in coolers
    By henrymark in forum Commercial
    Last Post: 18-08-2010, 02:43 AM
  2. Walk in cooler running 48degrees
    By cbslueck in forum Commercial
    Last Post: 16-04-2010, 05:00 AM
  3. Design td on walk in cooler
    By IMSTIEN in forum Technical Discussions
    Last Post: 01-10-2009, 10:18 PM
  4. Replies: 3
    Last Post: 02-07-2009, 04:47 PM
  5. walk in cooler EVAPORATOR coil icing up
    By kurt854 in forum Fundamentals
    Last Post: 14-06-2007, 07:28 PM
