Thread: Daikin split fault
13-10-2010, 02:45 AM #1
Daikin split fault
Hi guys, I have a daikin rxd71jvea unit that is putting out a "main circut over voltage or low voltage" fault.. Input to unit is 230v and fine. any ideas? Cheers
13-10-2010, 09:32 PM #2
Re: Daikin split fault
Is the fault code that you have U2?
Have you followed the fault finding procedure from the service manual?Brian - Newton Abbot, Devon, UK
17-10-2010, 02:15 AM #3
it sounds like you may have a board fault on that unit, check the compressor and fan motor, make sure there is no visual signs of burning on the outdoor boards.
17-10-2010, 07:46 PM #4
Daikin Split inverter external unit fault
By apounder in forum Trouble ShootingReplies: 2Last Post: 18-05-2010, 10:47 AM -
Daikin fault
By SkyWalker in forum Air ConditioningReplies: 7Last Post: 16-09-2009, 09:09 PM -
Daikin r407c 2 pipe vrv ja fault code any offers?
By Contactor in forum Air ConditioningReplies: 11Last Post: 28-07-2009, 01:26 AM -
Daikin Split f3 Fault
By moondawn in forum Air ConditioningReplies: 18Last Post: 01-06-2009, 07:09 PM
