Thread: Bitzer compressor unloader
08-10-2010, 01:25 AM #1
Hi everyone!
I got some problem with the Bitzer unloader. After we install and activate the unloader the hi & low side balances the pressure. How are we going to address this problem. The supplier supplied only the cylinder head and the valves without changing the valve plate cover.
Hope to received any answer from you. Thank you
regards,
RINBERT
08-10-2010, 07:26 PM #2
Re: Bitzer compressor unloader
Hi mate it could be several reasons , you might have start unloader instead of capacity control unloader, on the head it self it should say SU or CR. the valve plate does,nt need to be changed. or if you have a start unloader the valve piston in the head might be stuck open (at the top),to check take of the solnoid valve and see the piston goes up and down.
Bitzer gasket
By Renato RR in forum FundamentalsReplies: 5Last Post: 04-11-2010, 10:08 AM -
Bitzer s6f30 2-stage compressors
By JONAH in forum Technical DiscussionsReplies: 25Last Post: 27-10-2010, 07:27 AM -
Bitzer CSH8561-125Y oil sight glass
By Peter_1 in forum IndustrialReplies: 40Last Post: 26-05-2010, 04:32 PM -
Bitzer screwpack vibrations
By KosmisB in forum Trouble ShootingReplies: 2Last Post: 05-03-2010, 02:42 PM -
Oil pressure Bitzer
By coolcmt in forum CommercialReplies: 10Last Post: 25-09-2009, 07:09 AM
