Thread: retard
    farouk khan's Avatar
    farouk khan Guest
    retard
    Getting acquianted with manifold guage. why does the low side stay on retard like foreever, when i turn off the machine?
    Oct 2008
    mallorca, spain,
    75
    768
    Re: retard
    hi for khan,
    eather your suction gauge is stuck < or brocken< or the system has pumped down from a solinoid valve, or you have left a valve open on your gauges,
    why you turn off the machine?
    Re: retard
    Depends on type of machine you are using it on.
    For capillary unit the pressures will equalise when system off. If settle pressure above the 'retard' mark then gauge will stay there.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: retard
    What do you mean by retard?
  1. Why is suction gauge reading retard during charging?
    By acrefconsultant in forum Technical Discussions
    Last Post: 27-09-2009, 08:57 PM
