    cameron's Avatar
    cameron Guest
    de-super heaters
    im a trainee and im trying to find out all i can about these de-super heaters....
    dose anyone have like an idiots guied to them?? or explain what they are what they do?
    cheers
    Apr 2001
    79
    5,071
    35
    Re: de-super heaters
    Mar 2010
    UTAH
    De superheaters are used to lower the temperatures of superheated steam to the desired level by injecting the coolant via rapid heat transfer.
    Highly efficient, rugged and proven systems designed to lower the temperatures of superheated steam within the shortest possible distance from the De superheater, via rapid heat transfer by injecting the coolant.
    Quote Originally Posted by tom.smart71 View Post
    Unfortunately we are not talking about steam here, this is relating to refrigerants.
    ravi.r's Avatar
    ravi.r Guest
    hi,
    i am new to RE. i have a problem with my copeland compressor motor winding. model no d6rl2-2500-awm/d. can anyone help me. i want to get the motor rewound. thank you.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Does this compressor have a de-superheater perhaps? If not, then you are most likely in the wrong thread.
    Aug 2009
    New Zealand
    2,554
    What i am going to say is not 100% factual, but enough for you to understand the basics.
    To turn a low pressure gas (suction on a fridge system) to high pressure gas (discharge) you require power, this power ends up being heat, the discharge becomes highly superheated "hot" (sensible heat). A de-superheater, is a heat exchanger, that removes this sensible heat from the refrigerant, adding it to say water (heating the water) free heating!
    How ever, you need to careful when selecting the heat exchanger, many now a days, select on the water heating side, and overlook what happens to the refrigeration system (I see to small heat exchanger installed where the head pressure increases, driving up input power and reducing net refrigeration effect)
    3,853
    Quote Originally Posted by ravi.r View Post
    hi,
    What sort of help are you looking for?
    Why not take your compressor to a compressor rebuilders? they will be able to rewind it for you and check it over mechanically.
  1. carrier 30gx oil separator heaters
    By Coolie in forum Trouble Shooting
    Last Post: 12-05-2010, 05:58 PM
  2. seting super heat
    By citytosurf in forum Commercial
    Last Post: 05-02-2009, 03:14 AM
  3. Flame Proof heaters for the drain pan
    By smpsmp45 in forum NH3
    Last Post: 28-06-2008, 12:34 PM
  4. Crankcase heaters on splits?
    By Makeit go Right in forum Air Conditioning
    Last Post: 12-06-2007, 08:16 PM
  5. Searle Evaporator Heaters
    By Abe in forum Commercial
    Last Post: 31-12-2005, 10:24 AM
