Results 1 to 30 of 30
Thread: hiyasu inverter
31-12-2006, 09:24 AM #1
hiyasu inverter
hi to you all . I have a problem with a twin split hiyasu inverter ,the unit was fine and then it tryes to start up the outsite fan runs then 10 sec later it cuts out and flashes the green and orange led on the indoor unit. any sugegons
31-12-2006, 11:25 PM #2
Re: hiyasu inverter
Sorry Coolflow, the only info I can get from the Hiyasu website is a brochure and phone number, might be worth a try..
Servicio de Posventa. -En el menú de la izquierda puede elegir la gamade productos que le interese. Si no encuentra solucióna su problema a través de las preguntas más comunespuede hacer una consulta directa.El equipo de Hiyasu hará todo lo posible para resolvercualquier duda que pueda tener.El teléfono de Asistencia Técnica es el 902 15 39 91.Brian - Newton Abbot, Devon, UK
01-01-2007, 08:14 AM #3
Re: hiyasu inverter
thanks brian , i wasent sure if any one had had this prob before but its worth a couple more days ,thanks.
06-01-2007, 03:33 PM #4
Re: hiyasu inverter
Hi I have the same prob on a hiyasu multi did you get anywhere with your broblem
07-01-2007, 07:55 AM #5
Re: hiyasu inverter
no only that i have had this befor on another unit excactley the same , and solved that by turning the power off fot 15 mins and that cured it. but dont ask me why (no sabe).
14-01-2007, 04:07 PM #6
Re: hiyasu inverter
Hi coolflow CRC hear thanks for the info it worked for me too !!!!!
15-01-2007, 09:22 AM #7
Re: hiyasu inverter
good to hear. where are u in spain?
11-01-2008, 01:17 PM #8
Re: hiyasu inverter
Hiyasu Inverter. Any help on running it on heat, after about 5-10 min it cuts out and all lights flash? Works all day on cool.
11-01-2008, 04:44 PM #9
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: hiyasu inverter
Tel me model no. and flashing pattern of led diodes.
13-01-2008, 07:34 PM #10
Re: hiyasu inverter
I found this on the internet which may be of interest.
Most People have not heard of Hiyasu or Daitsu but they are actually the specialist air conditioning side of the Fujitsu Brand. They are highly regarded as the best mid range units available and manufacture a huge veriety of units from wall mounted to ducted systems. They come with a 2 year guarantee. Please click on the 'Hiyasu' link above to look at some of the Hiyasu range we can supply.
If they are simply fujitsu units you may want to look up Paulh on this forum. He has an extensive knowledge of these units.
13-01-2008, 08:02 PM #11
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
14-01-2008, 04:11 PM #12
Re: hiyasu inverter
Hiyasu are a Fujitsu in disguise, I know as I have a hiyasu badge that managed to escape the factory stuck to a Fujitsu unit As such they do have a similar fault / error display and if you provide the model number I will find the info.
Aircon in spain as nike123 has said "what is the flashing pattern of the lights" how does the red, green and possibly orange lights flash. Are you an end user or a technician trying to get help to fix a unit? I would expect the end user to just say "the lights are all flashing" but not a technician.
21-11-2008, 11:01 AM #13
21-11-2008, 11:20 AM #14
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
12-03-2009, 08:29 AM #15
Re: hiyasu inverter
Hi Nike123
I have a problem with a friends HIYASU airconditioning unit in that they have lost the mando control for it.
The Model Number of the unit is;
HSE 17 TW 03
And I am told the model number of the mando is;
9 AHH0269
Would it be possible for you to let me know if I can get a replacement mando either new or second hand? If that is not a possibility, is there a way to opperate the unit by hand, simply turning it on and off?
Thank you in advance for your help.
Best regards,
Paul
12-03-2009, 08:48 AM #16
Re: hiyasu inverter
If you can´t find the correct controller, then you could use a universal one as a last option. They sell them in Pecomark.
Or you could contact Hiyasu direct,
HIYASU S.A.
Entenza 332-334 6º1º
08029 Barcelona
ESPAÑA
Tel. 93 363 21 40
Fax 93 363 10 18
As. Técnica 902 15 39 91
There will be a hand button somewhere on the indoor unit, likely on the right hand side of the indoor unit, near the electrical connections.
12-03-2009, 09:10 AM #17
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: hiyasu inverter
Here you could try to find replacement universal remote.
I am not familiar with Hiyasu model numbers.
Could you describe unit:
shape (wall mounted, floor mounted, etc..)
year of purchase
refrigerant used
single or multi
13-03-2009, 09:46 AM #18
Re: hiyasu inverter
Thanks for your help guys..............though the only info I have is that it is a split unit, large in size with these following details;
Serial Number: AA3710E0200AE45H7262
Model Number: HSE 17 TW 03
0405
Outdoor Unit: HOE 17 TW 03
Capacity: 5.20 Kw Cool, 6.0 Kw Hot
If it isn't possible to gat a mando, where can I get a multipurpose one from? I see Pecomark mentioned, but not heard of them before? Is it like going to the shop for a multi purpose TV one?
13-03-2009, 03:21 PM #19
Re: hiyasu inverter
Hiyasu is rebadged Fujitsu.
i think it will be a ASE17A system wall mounted europe system, try calling Fujitsu UK for some help +44 (0)20 8731 3450
14-03-2009, 08:39 AM #20
Re: hiyasu inverter
14-03-2009, 09:34 AM #21
Re: hiyasu inverter
Pecomark are all over Spain.
http://www.pecomark.com/index.asp?Id...eb2008Espa%F1a
15-03-2009, 12:23 AM #22
Re: hiyasu inverter
If you are near malaga or fuengirola you can pick one up easy from cef electrical supplyer.
06-03-2010, 04:25 PM #23
Re: hiyasu inverter
As a Hiyasu end user I too have problems with flashing lights and non-operation of an inverter unit. On start-up all seems well but after about 2 mins the green light starts to flash at approx 1 second intervals and nothing else happens. On advice I cut the power for about 10 mins. No difference. I was then told that a number of hours was need. After 5 hours the computer semmed to have re-booted an now the unit works very well on cooling. Still no joy with heating. The gas pressure has been checked and is OK. Ny further suggestins would be appreciated.
07-03-2010, 07:08 PM #24
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: hiyasu inverter
What is your full model number of indoor unit?
08-03-2010, 05:49 PM #25
09-03-2010, 07:34 PM #26
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: hiyasu inverter
That is Korean manufacturer Fujitsu supported budget brand. That is not same as above original Fujitsu brands
http://www.busytrade.com/selling_lea...er_Daitsu.html
08-09-2010, 06:15 PM #27
Re: hiyasu inverter
I am an end user in Spain with an ongoing problem with a hiyasu inverter unit approx 6 years old. In the winter theunit would run for 15-30 secs then cut out and the green light flashed continuosly with no other pattern or sequence. I tried shutting power for 15 mins-no good. Was advised to try 2 hours-no good. This summer the same unit is giving intermittent probs with the sams grren light flashing all the time in failure mode. Again cutting power does not encourage the computer to fix the problem. A couple f local guys have had a look-one said the pressure was low and topped it up (did not measure the amount of gas), the other guy said the pressure was ok. Any help would would be greatly appreciated.
13-09-2010, 03:44 PM #28
Re: hiyasu inverter
From what you say I do not think this has anything to do with "gas pressure" and the flashing light means the air conditioner is trying to tell you it has an error which is most likely within the inverter mechanism.
When the green light is flashing press the Test run button on the remote control and the flashing light pattern will change.
Please tell us the MODEL number of the air conditioner and also the second flashing light pattern.Last edited by ozairman; 13-09-2010 at 03:46 PM.
20-09-2010, 10:02 PM #29
Re: hiyasu inverter
Hi Airefresco,
Have a look at the Eurofred. es website. You will find Hiyasu and Daitsu brands along with General. It is common knowledge that General and Fujitsu units differ only with model prefix and badge.
We have installed both Hiyasu and Daitsu, and the only difference was the badge. At the same time, we have some s/h floor/ceiling units badged Daitsu and General, and to all intents and purposes are the same.
RealCoolMan
We need the model number to assess the light pattern. This is important.
There are two levels, the first is the blinking of the Operation and Timer lights, and there is a second level that is accessed using the 'test' button on the remote.
All the best, GrahamLast edited by aircon50; 20-09-2010 at 10:26 PM. Reason: Missed out text!
en boca cerrada no entran moscas
21-09-2010, 08:40 AM #30
Re: hiyasu inverter
Whats confusing is there are two Daitsu´s, Daitsu and Daitsu Electric. The ones we normally deal with are the Daitsu you mention from Eurofred. The Domestic range is nothing like Fujitsu (or the others) I think they are Galanz or something. Daitsu electric are definitely Fujitsu units re-badged, they look identical and have the same names and everything.
Daitsu Electric
Daitsu
