    Jul 2007
    Rheem gas-pac air path designs, old vs, new insights?
    Old design: 1989 RRGG:
    -return-->(blower)-->clamshell gas heat exchanger-->evaporator--> supply
    New design: 2008 ish RRNL:
    --return-->evaporator-->(blower)-->tubular heat exchanger--> supply
    So, the old design had everything on push side and evaporator was placed after the heat exchanger.
    New design pulls through evaporator, then pushes through through heat exchanger.
    What are the pros and cons of the two designs?
    The new design seems to be built a lot sturdier, by the way.
    Re: Rheem gas-pac air path designs, old vs, new insights?
    With the new design it allows for dehumidification with reheat.
    Jul 2007
    It also makes the heat exchanger cold and precipitate water soon after A/C turns off.
  1. Help for fridge designs in bar
    By paddy68 in forum Technical Discussions
    Last Post: 10-05-2006, 08:49 AM
