    jh67's Avatar
    jh67 Guest
    how to check oil level heremetic comp.
    in order to check proper oil level in a heremetic comp. with a sight glass does the comp. need to be on or off, please help
    Oct 2006
    1,843
    Re: how to check oil level heremetic comp.
    Quote Originally Posted by jh67 View Post
    It should not alter much between on or off.
    But mostly they are done when running and again
    normally there are marks for the max and the min levels.
    taz
    May 2008
    66
    802
    normally it has to be of. but watch if the comp is running for nice movement. and the oil may not foam.
    Ice
  1. mini splits how to check charge level?
    By capthummel in forum Air Conditioning
    Last Post: 03-10-2009, 02:49 PM
  2. "Unstable" Rack Receiver Liquid Level
    By chweber in forum Commercial
    Last Post: 09-02-2009, 08:58 AM
  3. running the oil pump to check oil level
    By Ice Queen in forum Technical Discussions
    Last Post: 02-08-2008, 05:23 PM
  4. Risk in high compressor oil level?
    By Ice Queen in forum Trouble Shooting
    Last Post: 20-05-2008, 02:28 PM
  5. Air conditioning maintenance procedure
    By Andy T in forum Air Conditioning
    Last Post: 27-05-2006, 06:57 PM
