    friarsgate's Avatar
    friarsgate Guest
    sea water lobster tank
    commercial lobster fisherman needs to keep lobsters cool tank size 3.5m x 4m x 0.7m deep temp 3-4 deg water temp 8-12 deg c he cools it all at the moment with a large air cooler
    Re: sea water lobster tank
    OK, thanks for the info.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    But the lobsters said to the fisherman that the large air cooler was not good enough to keep their cool and would go on strike unless ICE was supplied.
    Jun 2007
    Cyprus
    73
    252
    Standard 2 HP air cooled condensing unit linked to a shell in tube evap.
    Salt water/Refrigerant exchange.
    Thermostat, water valve, external pump, UV filter, Good supply of sea water, and plenty of good rubber bands for those claws
    Sep 2003
    ISRAEL
    72
    4,248
    For sea water\refrigerant HE you need stainless steel 316L or titanium.
  1. hot water outlet position in water tank?
    By billliu2010 in forum Heat Pumps
    Last Post: 13-04-2010, 01:23 PM
  2. Ice Bank Tank for Chilled Water
    By Samarjit Sen in forum Commercial
    Last Post: 31-10-2009, 09:18 AM
  3. Need Help with cold water tank design
    By ac_sheldon in forum Industrial
    Last Post: 21-11-2008, 11:24 PM
  4. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
