Results 1 to 13 of 13
Thread: DWM DKSLA R/12 Copeland
23-08-2010, 09:35 AM #1
Hello everyone. We need the data on this compressor precisely its strength to 0, -5, -10, -15, -20.
23-08-2010, 04:27 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: DWM DKSLA R/12 Copeland
Nema tog modela. Provjeri oznaku.
There is no such model # in Copeland data base. Find correct model #.
Correction, it is such model number but without "R/12" part!Last edited by nike123; 24-08-2010 at 05:24 PM.
24-08-2010, 03:48 PM #3
Thanks team Copeland replacement for him is 15x R 134
24-08-2010, 04:58 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
D= DWM Copeland
K= 2 cylinder
S= long stroke
L= 9,1 m3/ displacemant at 1450 o/min (50hz)
A= model variation (A-P)
-= separator
15= motor size (15 or 20 )
X= POE oil
What is use of your compressor? By asked conditions i suppose MT (medium temperature) refrigeration.
24-08-2010, 07:50 PM #5
Milk cooling tank was used to 1200l.
Can you replace it DANFOSS-Maneurop MT 28?
24-08-2010, 08:26 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
24-08-2010, 08:36 PM #7
Milk cooling tank was used to 1200l,but the day bringing 500l of milk.
24-08-2010, 09:18 PM #8
I want to replace 150 R/12 DKSLA DWM Copeland is defective for the new DANFOSS Maneurop MT-28 to R22.
24-08-2010, 09:39 PM #9
24-08-2010, 09:49 PM #10
I want to change the DWM DKSL 150 R 12 for the new Danfoss Maneurop MT 28 R 22
24-08-2010, 09:50 PM #11
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Koji češ plin koristit?
It is not clear what refrigerant you plan to use.
If you are going to use R22 instead of R134 or R12 than for same capacity as original compressor (if that is original one) you need MT22 compressor and new TXV like TEX2 with 02 orifice.
Mislim da si takav odgovor već dobio na Fanzi.Last edited by nike123; 24-08-2010 at 10:36 PM.
25-08-2010, 09:07 AM #12
I'll take the R22, which goes with the MT 28 course that will change the valve, filter and nozzle
Excuse the spelling, I write it using Google Translate
25-08-2010, 03:08 PM #13
Re: DWM DKSLA 150 R/12 Copeland
Hello everyone. We need the data on this compressor DWM DKSLA 150 R/12 Copeland precisely its strength to 0, -5, -10, -15, -20.
Copeland Scroll Advanced Protection Problems
By dwayne in forum Trouble ShootingReplies: 8Last Post: 24-09-2010, 06:54 AM -
Copeland Manuals
By rcannon in forum Industrial CompressorsReplies: 2Last Post: 14-09-2010, 05:46 PM -
copeland scroll durability
By Third_techtrio in forum Technical DiscussionsReplies: 16Last Post: 23-01-2010, 04:47 AM -
Copeland screwcompressor
By Isbjorn in forum Technical SpeculationsReplies: 0Last Post: 02-12-2009, 11:22 AM -
copeland Digital Scroll
By supermarketguy in forum Supermarket RefrigerationReplies: 3Last Post: 17-10-2008, 09:09 PM
