Results 1 to 49 of 49
Thread: using nitogen when brazing
Threaded View
31-07-2010, 06:45 AM #30
Re: using nitogen when brazing
Yes I did Tycho - this is in fact one of the courses I give for PPL where I explain how the body reacts with changing heights and pressures and the phenomenas associating with this - but the point is that we replied to a post of James10 where he said that you will be dead with one (!!!) inhalation of OFN and this isn't true.
You're speaking of a whole room filled with OFN and you stay in there for an hour. That's an apple/pear comparison you're making now.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Brazing vs. soldering
By DaBit in forum FundamentalsReplies: 28Last Post: 19-03-2011, 11:50 AM -
Brazing in compressors?
By troymedhurst in forum Air ConditioningReplies: 20Last Post: 23-08-2010, 08:35 PM -
Flux and no flux brazing
By SkyWalker in forum FundamentalsReplies: 7Last Post: 09-05-2010, 10:43 AM -
brazing rod standards
By brian1 in forum CommercialReplies: 5Last Post: 02-05-2009, 12:00 AM -
Brazing Procedure Qualification
By Delboy in forum FundamentalsReplies: 13Last Post: 18-12-2007, 07:04 AM
