22-07-2010, 12:19 AM #1
Beko Frost Free Fridge/Freezer - Electrical Smell
Problem with my Beko Fridge/Freezer Frost Free Model CGA 9756 FFW
There is a strong electrical smell which occurs every few weeks' may be something to do with the frost free system? I have noticed that the smell occurs when the back panel has water droplets and not ice.
Also two holes have appeared at the back of the fridge compartment. (pic) img28.imageshack.us/img28/5170/beko.jpg
any ideas please?
24-07-2010, 07:02 AM #2
Re: Beko Frost Free Fridge/Freezer - Electrical Smell
Hi Jazzy, Does the fridge ever tripout the circuit breaker or earth leakage to your place?
24-07-2010, 02:43 PM #3
26-07-2010, 12:20 AM #4
Hi Jazzy, cannot bring up your pic, but i'd need to see these holes you talked about.
26-07-2010, 07:37 PM #5
29-07-2010, 01:12 AM #6
Jazzy, visual on your pic didn't work on my side. If your fridge appears to still be working fine( no ice building up anywhere) than (1) its possible the defrost element in the freezer section has shifted too close to plastic surroundings causing a burning smell or(2) an insulated heater wire surrounding the fridge section evaporator may be faulty, either way you should get it professionally seen to, cheers mike.
29-07-2010, 06:22 AM #7
Definitly have it looked at. You have the potential for a house fire, usually when asleep.
Electricity, [heat source ] oxygen and foam [ insulation,]. Can start as a hot spot and develop into an inferno in 30 seconds. Do you have smoke alarms.
magoo
So dump the fridge and start again.
29-07-2010, 11:18 AM #8
Fridge/Freezer now scrapped, better safe than sorry
Beko Frost Free - Freezing!!
By JonFreezer in forum DomesticReplies: 2Last Post: 11-07-2010, 10:11 PM -
Beko Frost Free Fridge Freezer failing to cool
By Derek Max in forum Trouble ShootingReplies: 1Last Post: 19-06-2009, 07:31 PM -
Zanussi frost free fridge/freezer is leaking water from the door
By joeyb1000 in forum DomesticReplies: 2Last Post: 12-10-2008, 09:41 AM -
Beko frost free freezer/fridge help needed
By DJT in forum Trouble ShootingReplies: 14Last Post: 22-12-2007, 12:13 AM -
Frost free fridge/freezer
By aircon in forum DomesticReplies: 0Last Post: 21-05-2005, 09:44 PM
