Thread: Daikin VRV3 Commissioning
24-07-2010, 11:32 AM #1
Hi guys
Can anyone tell me if you need to address the new Daikin VRV3 units on commissioning or do they set them selves up. As we have a unit with 11 units on it and when powered up the central control is not finding any units i would really like some help
24-07-2010, 02:55 PM #2
Re: Daikin VRV3 Commissioning
You need to put in group numbers into each indoor unit. Once you do the first group number 88 will disappear.
You should start at group 1-00 for your first unit and then to 1-10 for your 11 indoor units.
Hold down test button for 4 seconds then timer up and down to set group numbers then press confirmation button once.(Depends on what controller you have)No longer Active
daikin vrv3
By Eng_pius in forum Air ConditioningReplies: 2Last Post: 30-01-2010, 12:12 AM -
Daikin VRV3 iTouch/Vam unit question
By r0ss in forum Air ConditioningReplies: 7Last Post: 29-05-2009, 05:44 PM -
Daikin vrv3 oil return noise
By Suffolk Fridge in forum Air ConditioningReplies: 3Last Post: 03-04-2009, 05:37 PM -
Daikin Fault on Commissioning
By mchild in forum Air ConditioningReplies: 16Last Post: 28-03-2009, 02:56 PM -
daikin vrv3 vrs vrv2
By transit 1 in forum Air ConditioningReplies: 2Last Post: 23-12-2007, 06:51 PM
