Results 201 to 250 of 596
Threaded View
19-07-2010, 05:40 PM #11
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
From MP3000 manual;
CRR models are equipped with either 2 or 3
evaporator fans. All models feature 2-speed
motors. The evaporator fans operate continuously
to circulate air inside the container. The fans
operate on high speed for perishable cargo at
setpoints of -9.9 C (14.1 F) and above. At
setpoints of -10 C (14 F) and below, the
evaporator fans operate on low speed for frozen
cargo.
NOTE: If Economy Mode is ON:
Chill Loads: Evaporator fans operate on low
speed when container temperature is in-range.
Frozen Loads: Evaporator fans stop during the
Null mode; controller operates fans on low speed
for 5 minutes every 45 minutes.
Container Reefer Unit for Controlled Atmosphere (CA)
By reeferman in forum New TechnologiesReplies: 9Last Post: 26-08-2011, 09:26 AM -
Help cutting open 40ft reefer, we now have problems
By adrian_uk17 in forum IndustrialReplies: 50Last Post: 28-11-2010, 08:11 AM -
Reefer container
By stevec in forum CommercialReplies: 2Last Post: 25-01-2009, 05:30 PM
