    May 2006
    Isle of Wight, Uk
    47
    424
    pipes through flat roof
    Do any of you know where to get a galvanised roof cowl/riser thingy to enable pipework etc. to go straight up through a flat roof? I came across some on the net the other day whilst looking for something completely different, but cannot remember where. Need a couple for a job coming up.
    Andy
    Dec 2009
    35
    7
    Re: pipes through flat roof
    At the firm I work at we have used a product called "DEKTITE" for the situation you have said about.
    They come with different diameter holes in the middle to fit around the pipes.
    Type Dektite into google to see if it will meet your needs.
    May 2006
    Isle of Wight, Uk
    47
    424
    No, it's not a decktite. It's a small galvanised upstand with a removable top so you can pass the pipework through and bend back down towards the roof, then put the lid back on.
    May 2009
    uk
    44
    we always used to get the ducy manufacturer to knock them up andy
    May 2009
    uk
    44
    that should be duct
    May 2008
    170
    It's called a 'Roof-Nek' and made by 'Roof-Pro'.
    Decktite's are for ducting and you will not permanently seal multiple services passing through them. ie. pipes and cables.
    May 2006
    Isle of Wight, Uk
    47
    424
    Yep, that's the sort of thing. Looks a bit more expensive than the ones I'm thinking of though.
    Dec 2008
    I think the manufacturers of the big foot systems for flat roofs now do a galvanised riser for flat roofs, sorry no idea of there price.
    May 2008
    101
    The Big Foot Range of "swan necks" can be found here
    Jun 2010
    Ireland
    168
    I used to get a 4" or 6" roof fan casing without the fan guts somewhere. They were designed to be flashed, looked much better than something that the ducter would make up and I think were cheaper in the end. Ring a fan supplier and see if they will get a couple for you.
    I can imagine some savvy entrepreneurial forum member on Dragon's Den with an idea soon...
    jersey channel islands
    186
    what about a rubber slate with galvinised flashing attached, and a length of 4 inch rain water pipe with two 45 bends (push fit) and a pot of roof repair compound to seal the "rubber slate" to the roof.
    never had any complaints about leaks, from this cheap, but not very nice looking approach.
    you did not say if it was a ruberoid type roof , fibreglass, or a pvc heat welded roof ie sarnafil or similar, good luck.
  1. Fujitsu split pipes
    By gazza666 in forum Air Conditioning
    Last Post: 15-07-2010, 08:59 AM
  2. putting services on flat roof
    By b_m_services in forum Trouble Shooting
    Last Post: 17-05-2010, 05:34 PM
  3. Only first half of Pipes freezing?
    By Bobbin in forum Commercial
    Last Post: 09-04-2010, 08:45 PM
  4. Another boring install thread, chucking a unit on a roof
    By paul_h in forum Air Conditioning
    Last Post: 02-10-2008, 12:06 PM
  5. Installing pipes
    By tuneee in forum Fundamentals
    Last Post: 05-06-2007, 08:21 PM
