    Jun 2010
    maine
    reversing valve trane
    replaced rev valve in a trane water source heat pump told to replace cause coil half cold an hot on top i only weighed in 1 lb r22 c alls for three was gonna use the comp to pull the rest in but my pressures are equalized in heat mode an cool mode 150 suction an head pressure do i need the full charge to make the rev valve make a full stroke
    Re: reversing valve trane
    Yes, you always need the correct charge.
    Dec 2009
    New Zealand
    73
    Perhaps the valve was over heated when installed?
    Jun 2010
    maine
    no used thermal trap it was just undercharge
  1. Reversing valve leakage
    By Beck's Machine in forum Heat Pumps
    Last Post: 12-02-2010, 04:05 PM
  2. Reversing valve
    By R1976 in forum Air Conditioning
    Last Post: 12-08-2009, 07:17 PM
  3. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  4. goodman Cpkj60-1c Reversing valve
    By mastercheif602 in forum Air Conditioning
    Last Post: 15-07-2009, 02:58 PM
  5. Diagnosing reversing valve vs scroll compressor?
    By Larry2 in forum Technical Discussions
    Last Post: 10-05-2008, 01:25 AM
