02-07-2010, 07:21 AM #1
Low speed Variable Speed Screw Chiller
I was wondering what is the lowest speed that the compressor can go to on a variable speed screw chiller before the inlet guide vanes start to kick in. i assume it to be somewhere around 50% of Full Load speed but not sure.
Does this speed change at different conditions or with different manufacturers?
02-07-2010, 09:25 AM #2
Re: Low speed Variable Speed Screw Chiller
In general minimum speed on most makes is 1440rpm .
This is because of rotor tip speed and sealing against casing .
02-07-2010, 10:31 AM #3
No inlet vanes in screw compressors
02-07-2010, 11:54 AM #4
02-07-2010, 02:33 PM #5
Variable speed motor theory help
By Contactor in forum ElectricalReplies: 12Last Post: 17-05-2010, 05:24 PM -
Energy efficiency of air-source heat pumps with variable speed compressors
By BoardMan in forum FundamentalsReplies: 14Last Post: 27-01-2010, 02:32 AM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Variable speed screw compressors
By Friobernal in forum Industrial CompressorsReplies: 1Last Post: 14-11-2004, 09:28 AM
