29-06-2010, 03:14 PM #1
Calculate Operating Expense on Walk In's
I am trying to some information for a large customer of mine who is doing an evaluation of the expense to pull a walk in cooler back down after they leave the door open for an hour. We know that the temperature is averaging up 4 degrees during this period. How much does it cost to pull back down?
29-06-2010, 05:15 PM #2
Re: Calculate Operating Expense on Walk In's
Measure your system running amperage for the time it takes the cabinet to drop the 4 degrees and multiply it by the cost per kWh
Example:
Time taken, say 3 hours
Current draw, say 10Amps
Amps x Voltage (10 x 230 UK) = 2300W or 2.3kW
2.3kW x 3hrs = 6.9kWh
6.9kWh x cost per unit = cost to pull down 4 degrees.
30-06-2010, 02:15 PM #3
that sounds too simple LOL I will pass this on.
walk in freezer
By ail in forum RefrigerantsReplies: 8Last Post: 29-11-2009, 11:44 PM -
walk in freezers
By johnnyboy in forum CommercialReplies: 13Last Post: 01-10-2009, 08:10 AM -
Calculate condenser capacity?
By Henry. in forum FundamentalsReplies: 5Last Post: 26-06-2009, 07:48 PM -
Help with Walk Ins
By DonaRose in forum CommercialReplies: 1Last Post: 06-06-2009, 03:07 PM
