Thread: high discharge superheat
28-06-2010, 07:14 AM #1
Hi! One of our customer has a 500T centrifugal chiller of Mcquay. The discharge super heat is slightly higher and even on opening of liquid injection port, there is neither a drop in the superheat, neither any reduction in the noise level. We checked with all valves on the injection line and all seem to be fine. Also the compressor has been recently overhauled.
Pls suggest.
28-06-2010, 05:18 PM #2
Re: high discharge superheat
hi Dheeraj, are all the valves open? is there psi on all 3 pressure dials on the controle facia? can you get the overall firm back to <run it up?< all the best , sedgy
9 superheat & subcooling scenarios
By nike123 in forum FundamentalsReplies: 39Last Post: 19-07-2011, 03:16 AM -
Superheat
By marc5180 in forum FundamentalsReplies: 130Last Post: 27-04-2011, 02:35 PM -
19XL High Discharge Temp intermittent alarm at compressor start
By pete_d in forum CommercialReplies: 5Last Post: 08-11-2009, 05:10 PM -
Grasso 69, Discharge Temp to High
By Jomoniak in forum NH3Replies: 14Last Post: 05-07-2008, 07:58 AM -
How do you calculate Superheat?
By zolar1 in forum TrainingReplies: 39Last Post: 10-05-2002, 02:37 AM
