Thread: Pump Alignment
24-06-2010, 01:25 AM #1
Pump Alignment
In the next week I am going to have to align the 3 chilled water pumps for the new Trane screws my company just installed. Problem is, it's been ages since I've done one and I want to do it the correct way, not just use a straight edge. My company also doesn't have 5K to drop on a laser tool, so any advice or direction to a good alignment website would be appreciated.
24-06-2010, 02:27 AM #2
Re: Pump Alignment
Laser tool not needed! A dial indicator does well.
Look up this link and it will tell you all you need to know.
http://www.carlylecompressor.com/Fil...ent_lowres.pdf
24-06-2010, 05:00 AM #3
Re: Pump Alignment
Thanks NH3LVR
I d.loaded and checked it out and it's a goodie.
24-06-2010, 10:10 PM #4
Re: Pump Alignment
Great book, thanks NH3LVR..
25-06-2010, 07:44 PM #5
Re: Pump Alignment
Great reference book, thanks very much.
Re: Pump Alignment
Very nice NH3LVR!
But a small tip, always ALWAYS! allign the machine sideways before you check the height.
if the machine is off sideways, they height will be off as well.
When I align machines, the first thing I do is make them parallel, even if they are off center.
when they are parallel I move the motor sideways and try to keep it within the parallel as I move it sideways.
Once you have the motor clocked in within the sideways tolerance you can start worrying about the height.-Cheers-
Tycho
26-06-2010, 01:17 PM #7
Re: Pump Alignment
Thanks for the advice and thanks for the link NH3LVR it's very much appreciated.
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
