Thread: Whirlpool k40 ice maker
26-01-2010, 02:58 PM #1
Had a look at one today for not making ice and found the evap frozen solid over the water feed pipe, and the heater grid broken and another lump of ice sat on the grid holding up the switch.
Managed to twist the ends of the heater wires together to get it working again
Anyway, when i go back with the new grid i'd like to know what the normal sequence these things go through when making ice, should it wait till the last lot has dropped into the bin till it starts again etc etc
Cheers Jon
26-01-2010, 03:15 PM #2
Re: Whirlpool k40 ice maker
when the slab has dropped onto the cutter grid the refrigeration cycle should start. there will be an ice thickness switch which initiated the hot gas defrost when the desired thickness is reached. check that this is not faulty
27-01-2010, 12:23 PM #3
Cheers Roy,
I'll check it when i go back.
Jon
22-06-2010, 08:49 PM #4
ice is nice
23-06-2010, 12:12 AM #5
Hi Jon
A handy tip is to turn the ice thickness stat until it clicks, think it maybe anti-clockwise but not sure, this initiates the defrost cycle & opens the water valve to fill the tank. If you do this on start up until water flows out of the drain at the back before ice making, it'll make sure the water tank is full.
It should go through this automatically on every defrost cycle in order to stop a build-up of minerals in the water tank & rank tasting ice..
If you try this link it's got some documentation-
http://www.whirlpoolk40.com/#/home/4531731977
I found them a bit of an odd-ball electrically, but once you've got your head round them, they're simple enough. Elec diagram should be on inside of the lid..Last edited by Gingerair; 23-06-2010 at 12:15 AM. Reason: Jumpers for goalposts...
23-06-2010, 07:38 PM #6
Just noticed this post was 6 mnths old....Doohhh !!!
Ice Cube Maker SWITCH
By rebels59 in forum DomesticReplies: 4Last Post: 16-07-2010, 03:56 AM -
whirlpool side by side
By paul_h in forum DomesticReplies: 5Last Post: 03-02-2009, 07:14 PM -
Whirlpool American Style Fridge Freezer
By kdavies3 in forum DomesticReplies: 1Last Post: 01-07-2008, 11:57 AM -
Ice Box on my Whirlpool Fridge/Freezer not working
By Chouman in forum Trouble ShootingReplies: 5Last Post: 18-09-2006, 01:23 AM -
Scotsman Dc33pa Ice Maker Troubleshooting
By Sean LaDart in forum Trouble ShootingReplies: 8Last Post: 13-02-2006, 08:01 PM
