    38
    Pressure Drop Calculation
    Hi all,
    I am hoping someone can help me, now I know I might get some abuse for this, mostly due to the fact it's to do with heating, not refrigeration... but I have been a member a little while now, even if my post count is so very low, and thought if anyone can help it's you guys...
    I have seen lots of formulae written on the net, and have tried to add my numbers to them, but to no avail... rather than using a program, I would like to understand it myself!
    For this example (although I'm making a spreadsheet with thousands of possible results for all types of fluid) could you please use:
    Mass Flow 200 kg/h
    pipe length 7100 mm
    pipe diam 37 mm
    pipe roughness 0.04 mm
    density (viscosity) 523.8 kg/m³
    Dinamic viscosity 0.0001 Pas
    Spec.Heat 2310 J/kgK
    Minor loss coeff. 1 (yet to work out an 8coil oval pipe)
    Temp in 30°C
    Pressure in 50Bar
    It may help, but you can calc from those:
    Vol. Flow rate 0.3818 m³/h
    velocity 0.09865 m/s
    friction coeff 0.026907
    kinematic visc. 1.909E-07 m²/s
    Reynolds 19118.275
    boundary layer thickness 0.4161 mm
    So please if anyone can calculate and show the working for pressure drop, I would most appreciate it.
    James
    5,667
    Re: Pressure Drop Calculation
    Quite an easy question for a Design Engineer I would have thought!
    Are you really a Design Engineer?
    Me, if I was Design Engineer I would use something like this in the absence of a friction loss section from my technical books.
    http://www.efunda.com/formulae/fluid...e_friction.cfm
    38
    Yes I am thanks Frank, well was a design engineer... new job is R&D engineer for a heating company... mostly new stuff to me.
    Where my last job was designing cold box type containers at a polystyrene moulding company, i'm now putting process heaters and air heaters on oil rigs and cement factories and anything else that may have a tendency to explode...
    So, being honest, I have little to no knowledge of fluid mechanics... give me a year or so and hopefully I will be able to answer everyone else's flow related questions, but for now I am leaning...
    As for the calc, thanks Brian, although it is coming out with different answers to the software the company has paid for... strange...
    5,667
    Thanks for that.
    I'll have a look in my notes, I'm sure I've got the formula somewhere......been such a long time since I used it.......
  1. NVQ 3 online test
    By Burrah Boy in forum Training
    Last Post: 28-10-2009, 08:35 PM
  2. duct pressure drop calculator
    By urajat in forum Tools and Calculators
    Last Post: 27-07-2008, 11:35 PM
  3. pressure drop and chillers
    By Dimitris in forum Technical Discussions
    Last Post: 30-05-2008, 08:33 PM
  4. Coil Pressure Drop
    By jwasir in forum Fundamentals
    Last Post: 15-04-2008, 08:41 PM
  5. pressure drop of two phase flow in valves
    By Hansss in forum Fundamentals
    Last Post: 24-06-2006, 05:10 PM
