    Berenger's Avatar
    Berenger Guest
    R407C pressure-temperature formula.
    Good morning.
    I am setting up a spreadsheet for the readings off our chilled water plant. I want to set it up so that TSAT for the condensor and chiller is automatically generated from the suction and discharge pressures. Does anyone know the formula to convert R407C pressure to temperature?
    Thanks in anticipation.
    Nov 2009
    Minsk, Belarus
    171
    Re: R407C pressure-temperature formula.
    There is a conversion table, but really I don't know formula for this gas.
    There is a formula for ideal gas:
    p*V=m/M*RT
    p - pressure [Pa]
    V- volume [m^3]
    m - mass [kg]
    M- molar mass [kg/moth]
    R=8,31 [J/(moth*K)]
    T- temperature [K]
    In some places will have to think ...
    Mar 2007
    118
    Try this: P-T chart for 407C is toward the bottom
    http://www.refrigerants.com/pics/ptchart.pdf
    Feb 2008
    Norway
    446
    I did make an Excell cheet for conversion of R404A pressure to temp some time ago. It is not complete in the sense it is probably necessarry to make another element like +POWER(F10;?)*? to make it accurate for higher temperatures. Currently it is acurate to within 0,6C for most of the range from -47C up to about +20C. Fine tuning the constants should probably make it more accurate. The result is temperature in degres Kelvin.
    The first formula is how the result cell looks in my excell sheet for validation. The next formula is how it may look in say a PLC.
    F10 is the pressure in Bar, absolute.
    I10 is a constant. This is the most "senior" constant.
    All the other non cell numbers is also constants. I have derived this formula by try and error so it is most likely it exists both simpler formulas as well as more acurate formulas. Altering the constants will make it correct for other refrigerants.
    LOG(F10;I10)*J10+L10+O10
    LOG(F10;5)*258,2+POWER(F10;1,8)*0,58+POWER(F10;3)*-0,187
    If you want the formulae used by DuPont then download this pdf file...
    http://www2.dupont.com/Refrigerants/...o_prop_eng.pdf
    The above is English units, if you want SI then select from the list here..
    http://www2.dupont.com/Refrigerants/...rature.html#pt
    Jan 2008
    qatar
    52
    61
    thanks for that above information
    TRY TO LEARN MORE ABOUT A/C SYSTEM
  1. Replies: 12
  2. How can I reduce evaporator pressure?
    By mansari in forum Fundamentals
    Last Post: 05-09-2009, 01:59 AM
  3. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  4. pressure and temperature drops in R22 evaporator
    By fedri in forum Refrigerants
    Last Post: 09-07-2006, 03:44 PM
  5. oil pressure problems on air dryer
    By edge in forum Trouble Shooting
    Last Post: 16-07-2002, 02:10 PM
