Thread: LCD monitor display screen
29-05-2010, 04:37 AM #1
LCD monitor display screen interface connecter pinout
29-05-2010, 10:41 AM #2
Re: LCD monitor display screen
You need to give us a question to answer with just a little more data. More specifics please
31-05-2010, 04:59 PM #3
Thank you Telsa,
I have a damaged AOC LM760 LCD screen (cracked), display lights up in certain areas,
But I want to replace is with another panel of similar size. (ACER V173 17 Inches)
My question is will the Active Matrix connector mates with the female receptacle of the other screen pin-for-pin and will it work?
Thanks again.
31-05-2010, 06:16 PM #4
AOC LM760 has 15 pin D sub connector. Cannot find the Acer model you mentioned online. If the connector is the same it will work
01-06-2010, 05:35 AM #5
Sorry guys, I finally found out how to ask for what I really want to know:
Is the LCD panel ribbon cable connector compatible between AOC LM760 and ACER v173?
Thanks.
01-06-2010, 08:51 AM #6
From a quick search on google it looks like the connections are different but you can buy a cable that will have the right connection. So yes the monitor will work and no the cable will need to be replaced.
01-06-2010, 11:04 PM #7
Thank you Telsa, Telsa is a great name, it always remind me of Alternating Current.
I am a-jack-of-all-trades and master none. But, I do have fun learning new things.
Thanks again.
Mitsi AG-150 Touch screen central controller
By DL A/C in forum Air ConditioningReplies: 1Last Post: 22-09-2009, 09:38 PM -
How to stop staring at my laptop screen?
By pinkblondi in forum CPU OverclockersReplies: 4Last Post: 12-06-2009, 02:01 PM -
oil separator screen cleanning
By coldkeeper1 in forum Supermarket RefrigerationReplies: 3Last Post: 08-07-2008, 06:19 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM
