Thread: Taylor 754-33 Mix Temp
20-05-2010, 03:30 PM #1
I have a Taylor 754-33 air cooled soft serve unit. The mix temp is running too warm on both sides. When I reduced the temp on the left side, the "Mix Set Point" light came on. I do not get this light on the right side, when I do the same. Can anyone explain the set point light.
I would also love to get my hands on a copy of the service manual for this machine, if anyone can download for me.
20-05-2010, 10:38 PM #2
Re: Taylor 754-33 Mix Temp
The book:
http://www.taylor-company.com/servic...literature.htm
You might want to call a refrigeration engineer (serviceman). As you'll see in the book worn beater bars could be the problem. You won't save a pile of money trying to fix it yourself. Taylor does have schools. Your choices not to make your problem worse by twisting on things :-) is either call a trained person or spend the dough to become said trained person.
MP66 & Compressor Overheating
By Intermez in forum Technical DiscussionsReplies: 111Last Post: 13-04-2010, 08:58 PM -
19XL High Discharge Temp intermittent alarm at compressor start
By pete_d in forum CommercialReplies: 5Last Post: 08-11-2009, 05:10 PM -
Temp. Rise at duct outlet
By jwasir in forum Trouble ShootingReplies: 13Last Post: 10-05-2008, 04:22 PM -
cold room temp & the product temp
By smpsmp45 in forum NH3Replies: 9Last Post: 21-09-2007, 11:46 PM
