Results 101 to 150 of 202
Thread: Refrigeration 101
Threaded View
18-05-2010, 08:47 PM #11
Re: Refrigeration 101
capillary...
Somewhere in the coil the flow of refrigerant is slower and also the pressure drops over the distance it has to traval? right?
so does it travel this distance loosing pressure in a small coil pipe in hopes when the refrigerent gets to the evap (larger pipe coil) its lost enough enough pressure to have a zillion vapour droplets colleting heat? like a thermal expansion valve, but with out the sensor or valve?
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
