    Mar 2010
    64
    7
    lowering micron readings
    Hi guys was thinking of purchasing 3/8" hose for my vacuum pump. Was told it will speed up evacuations and get me lower micron readings. The part i'm not sold on is the fact the hoses will attach to 1/4" schraders with 3/16" openings which will still choke everything down. 10 ton roof top units will be about the largest I will be working on Thank you
    Randy
    Hammer's Avatar
    Hammer Guest
    Re: lowering micron readings
    Randy, you actually want to go to a 1/2 inch hose to your pump from the system. It flows 16 times the more than a 1/4 inch hose and the greater the flow the faster it will go. The molecules slow down thru the 1/4 inch system fitting but speed up rapidly when they hit the 1/2 hose to the pump. Go to your local wholersaler and ask for the Appion 1/2 inch hoses. They are vacuum rated to 20 microns.
    Apr 2010
    Quote Originally Posted by Randykissling View Post
    Randy
    Analogy the Appion rep used I like is a 3 lane highway and a accident closes off 2 lanes. Once past the accident you're back up to speed. More flow than a single lane with no accidents.
    38
    The bigger the pipe and the shortest pipe will acheive a better and quicker low vacuum.
    Aug 2007
    Sydney
    52
    1,083
    Hi Randy
    as for the 1/4" schrouder restriction - get a couple schrouder valve removal tools. They can remove/replace the valve while gas is in the system saving a lot of evacuation time. One supplier is yellow jacket (ritchie).
  1. lowering micron readings
    By Randykissling in forum Technical Speculations
    Last Post: 02-11-2010, 03:41 AM
  2. micron to mm
    By sparo in forum Fundamentals
    Last Post: 05-01-2009, 11:11 AM
  3. Oil Filter micron
    By Iceehot in forum NH3
    Last Post: 26-09-2008, 02:49 AM
  4. accepable levels using a Micron gauge
    By kengineering in forum Commercial
    Last Post: 06-12-2007, 11:50 AM
  5. Humidifiers with 1 micron droplet size
    By sharshal in forum Technical Discussions
    Last Post: 11-05-2007, 07:35 PM
