22-04-2010, 11:37 AM #1
air cooled condenser size calc????
HI frns,
Can any help me to calculate total length of an air cooled condenser required for 1 TON water chiller.
Heat Load of chiller = 3.5kW
Condensing temp.=50 degC , evaporating temp.=5 degC, R407C gas, condenser tube dia.=9.525mm copper tube(plain) with aluminium fins,
secondary fluid(water) details:
inlet water temperature=20 degC
outlet water temp. = 15 degC
temperature difference = 5 degC
water flow rate =10 LPM
22-04-2010, 12:02 PM #2
Re: air cooled condenser size calc????
http://www.coolit.co.za/
You will find a number of useful software tools on this site, at very reasonable prices. I strongly endorse these products & use them myself.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
22-04-2010, 02:50 PM #3
23-04-2010, 04:04 PM #4
5,8 m is a rough estimate
24-04-2010, 06:03 AM #5
R410A water cooled condenser
By K.R.Iyer in forum FundamentalsReplies: 0Last Post: 04-02-2009, 02:10 AM -
By langy in forum Air ConditioningReplies: 2Last Post: 19-08-2008, 06:43 PM -
Air Cooled Condenser Leakage Problem with R-404A
By RADHAKRISHNARAO in forum Technical DiscussionsReplies: 19Last Post: 30-07-2008, 12:21 PM -
method to design air cooled condenser
By abbasi in forum New TechnologiesReplies: 4Last Post: 12-02-2008, 08:34 AM -
Making a simple water cooled condenser
By The MG Pony in forum FundamentalsReplies: 19Last Post: 01-08-2007, 11:02 AM
