    darko.josifovsk's Avatar
    darko.josifovsk Guest
    Candy Fridge Freezer not working properly
    I have a Candy fridge freezer (model CPA1612), I noticed does not switch off, it is constantly running making the food in the fridge compartment starting to freeze. I tried to lower the settings (the dial in the fridge) but does not react at all (I would expect it to click and turn it off), unless truned to zero - then it switches the applienace off an does not come on again when I turn the dial back up. I turn it off from the mains and few secods later turn it on again and it works continuously. Any ideas?
    Jul 2006
    norfolk
    737
    Re: Candy Fridge Freezer not working properly
    sounds like you need to replace the thermostat
  1. Waeco freezer cold fridge hot
    By lisney56 in forum Trouble Shooting
    Last Post: 25-12-2009, 11:43 AM
  2. Zanussi ZENB9950 Freezer cold fridge not
    By fkarim7 in forum Domestic
    Last Post: 03-09-2009, 09:10 PM
  3. Replies: 3
    Last Post: 04-08-2009, 04:24 PM
  4. Replies: 1
    Last Post: 24-03-2009, 07:47 PM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
