Results 1 to 50 of 52
Thread: H/p L/P switch settings
Threaded View
22-10-2004, 06:00 PM #19
Re: H/p L/P switch settings
Refrigeration is about temperatures, not pressures. When you learn to think in terms of temperatures, you can work with any refrigerant. A new refrigerant only requires a new P/T chart.
Back when only a few refrigerants were in common use, I told people to paint over the pressure scales on their gauges, so they would be forced to use the temperature scales. Temperature is what really matters.[/QUOTE]
temperature alone is as irrelevant as pressure in isolation. it seems slightly patronising - to me at least- when some say
' forget the pressure tell me the temperature'
it's nonsense you cannot diagnose by temperature alone..
if i said the suction pipe is 12 deg's c what's wrong?
could you tell me??????
i rather doubt it..
no you would give me a list of alternatives much the same if i said 'the pressures 34psig whats the matter?'
rant over back to the wine..;-))
cheers
richard
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
Supermarket Refrigeration System's Settings
By monsker in forum Supermarket RefrigerationReplies: 8Last Post: 10-04-2006, 02:18 AM -
RCV and HIGH PRESSURE SWITCH
By abbasi in forum FundamentalsReplies: 3Last Post: 22-03-2006, 08:51 AM -
shower switch fault !
By Krups in forum ElectricalReplies: 10Last Post: 19-10-2005, 09:10 PM -
Oil Pressure Switch
By Abe in forum CommercialReplies: 9Last Post: 15-03-2003, 11:18 AM
