Results 1 to 17 of 17
Thread: cornell pump
Threaded View
20-03-2010, 11:38 PM #5
Re: cornell pump
I do not believe so since the seal rides on the shaft of the motor. The movement and pulling could and probably would cause the seal to skid. I would go ahead and do a complete motor replacement or rebuild instead. If a motor bearing is about to go, other parts are not far behind. Replace the motor and seal, after you will have a like new pump. Of course, I am assuming you mean a direct drive style pump like 2cb, 2.5cbh, 1.5 cbh, 3cb. You can also contact the factory, tech support has probably faced the question or give you more insight. (503) 653-0330.
liquid ammonia pump calvitation
By Kathleen in forum Trouble ShootingReplies: 23Last Post: 20-05-2011, 02:18 AM -
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
