14-03-2010, 04:15 PM #1
Can I mount theindoor unit of split a/c in the middle??
A question for experts...
The indoor unit of split a/c is generally monted vertically on the wall.
I have 2 questions :
1. Can the unit be mounted in the MIDDLE of the room ( instead of wall ) on a suitable support structure? Is it necessary to block the bottom space ( upto floor ) with a thick curtain?
2. Can the indoor unit be monted in a slanting position? ( Always the vanes in the outlet direct the air towards the front .. instead can the unit utself be monted pointing the lower portion to front?)
This should be more efficient because the air will be directed towards the front naturally .. instead of it striking the vanes and getting reflected to front ..
I am a total illiterate as far as air-conditioning is concerned.
S^3
14-03-2010, 06:04 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Can I mount theindoor unit of split a/c in the middle??
You have cassette units or floor standing units!
14-03-2010, 08:13 PM #3
The unit can be mounted where ever you want but it must be mounted vertically.
Inside the unit, under the cooling coil, is a drain tray for collecting moisture from the coil.
This needs to be drained from the unit by gravity unless you get a special pump to suck the water up from the drain.
Remember that the pipework needs to be installed as well as the electrical supply.Brian - Newton Abbot, Devon, UK
Roof Mount Split System Installation Photos
By Jethro Bush in forum Heat PumpsReplies: 0Last Post: 12-07-2009, 10:26 AM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
What is the best way to mount a split to a wall?
By paul_h in forum Air ConditioningReplies: 18Last Post: 28-09-2008, 03:57 PM -
Do you beleive in data of split units?
By jirhol in forum FundamentalsReplies: 4Last Post: 29-03-2008, 11:17 PM -
Mitsubishi 10kw Wall Mount Split Impeller?
By Muggsy in forum Air ConditioningReplies: 2Last Post: 22-02-2008, 05:16 PM
