Results 101 to 150 of 224
Thread: Strange TXV setup
Threaded View
13-03-2010, 08:52 PM #10
Re: Strange TXV setup
I think we need to step back from the tech areas for a short while, we need to look at the process.
1: do we need to ensure that pull down is achieved with 2.5hrs.
2: Which cabinet is used the most.
3: Does Chef, want/can make possible major changes. (what can be completed without destroying the cabinets)
4; What level of controllabilty is required.
From my point of view, the system is presently running short of refrigerant, causing high superheat, and then the SH is made even worse by the Suction/liquid line heat exchanger.
Can't suss strange paramaters on Denco downflow unit
By Coolie in forum Air ConditioningReplies: 20Last Post: 26-07-2010, 03:20 PM -
The Basic Setup
By ice_cold in forum FundamentalsReplies: 5Last Post: 17-12-2009, 09:34 AM -
Fujitsu strange Whistling noise
By gwilliamson in forum Air ConditioningReplies: 17Last Post: 26-03-2008, 09:48 PM -
Hermetic strange sound.
By fridg in forum Technical SpeculationsReplies: 16Last Post: 02-03-2008, 07:08 PM -
strange inverter problem
By rbartlett in forum Air ConditioningReplies: 11Last Post: 19-05-2006, 08:31 PM
