Results 1 to 47 of 47
Thread: T.E.V. adjustment.
Threaded View
18-08-2001, 02:20 PM #11Where I work, we do it by saturated suction temp & actual pipe temp difference.
Note that attempting to set the TEV to control a low superheat, say below 4°F, can be tricky. The problem, of course, is the accuracy of one's gauges and temperature probe. The Prof recalls a technician who was amazed that he could be the TEV to control an absolutely steady 1.7°F superheat. The Prof, of course, suggested that he adjust the TEV in somewhat, and get his intruments better calibrated if he plans to continue having the TEV control low superheatsProf Sporlan
Expantion valve adjustment
By ayaz in forum Technical SpeculationsReplies: 5Last Post: 22-04-2006, 03:43 PM -
Pressure control adjustment and Case temperatures
By mccoolair@yahoo in forum Supermarket RefrigerationReplies: 3Last Post: 08-04-2006, 12:21 AM
