Results 1 to 50 of 54
Threaded View
22-02-2010, 05:14 AM #22
Re: Capillary tube size, refrigerant, oil
As I've read, it will be closed on system start, until sufficient SH has been reached, after which it will open.
A cap has its place, and indeed can equal a valve at a fixed point, "Optimum", but there are very few systems where all process variables are constant, thus keeping the system at optimum.
In other words, what process variables, or grouping of variables, needs to remain fixed, in order for a cap tube to work over a wider operating range? If both Te & Pc slide together, is there a group that remains relativley constant? Perhaps it is time we re-think a little more about cap tubes?
Practically a valve does allow for inperfection in design, as a cap needs to be right. For one off applications, the time spent optimising the cap, (cost) will be greater than the value of the valve installation.
I agree that present software is an aid to cap selection, no a fixed solution.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
Where can I get copper capillary tube
By hiloo in forum Air ConditioningReplies: 4Last Post: 21-06-2011, 11:04 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
capillary tube design
By Chris Zahrt in forum FundamentalsReplies: 5Last Post: 04-06-2009, 09:16 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
capillary tubes and mass flow when fed with liquid/gas
By DaBit in forum FundamentalsReplies: 15Last Post: 24-10-2002, 06:52 PM
