    Mar 2009
    London
    Dual temperature refrigeration
    Is there such a patented refrigation system which can operate a storage room either as a cold room (+5 deg C) or as a freezer (-18 deg C) at the touch of a button. I can think of different ways of organising a refrigeration system to do this, but can one buy a system already designed for that purpose ?
    Harry
    38
    Re: Dual temperature refrigeration
    Harry who,
    money can do anything so long as you are prepared to spend.
    Did a couple for the AirForce here, worked sweet as, expensive though.
    Don't now about patents, as is regular refrigeration design, sorry bud. Check out regular transport refrig., systems and similar. Flick a switch between fresh or frozen.
    magoo
    India
    688
    Yes there are systems ready to use type made by Zanotti/ Technoblock etc & we have used them as well.
    If you are concerned about patents then you should check with the Patent Office also.
    Dec 2009
    usa
    Fairly common in supermarkets using "dual temp" cases. The switch energizes a bypass solenoid around an EPR and allows the case to run at compressor suction pressure (low temp). Release the bypass and the EPR will modulate and hold the pressure up in the evaporator and increase its SST.
    mefleh's Avatar
    mefleh Guest
    i guess there no problem of opert condensing unit for both +5 or -18 c as far there is heater inside the evaporatore and time for defrost should be evry 6 working hours
  1. advanced refrigeration technology
    Last Post: 16-02-2011, 05:22 PM
  2. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  3. Wrong temperature on control panel
    By swee'pea in forum Trouble Shooting
    Last Post: 14-01-2009, 09:18 AM
  4. Carbon Dioxide Refrigeration
    By Andy in forum CO2
    Last Post: 12-08-2008, 03:33 AM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
