Results 1 to 17 of 17
Thread: slide valve
12-01-2010, 07:03 PM #1
slide valve
Hi dear sirs
how does a slide valve work?
i can't find good answer for this question.
so, i'm looking for a hero to give me the gooooooooood answer
thank you all
12-01-2010, 07:15 PM #2
Re: slide valve
On what application is the valve ?
12-01-2010, 10:22 PM #3
Re: slide valve
on what aplication is this SLIDE VALVE? what dose it do?
12-01-2010, 10:44 PM #4
Re: slide valve
A slide valve is a method of loading and unloading a screw compressor. It simply covers more of the flutes of the screw and opens the delivery port a little more that is all.
The Bridge Keeper
'Answer me these questions three, n'er the other side ye see.'
What is your name?
What is your favourite colour?
What is your suction superheat?
13-01-2010, 02:46 AM #5
Re: slide valve
If you visualize the slide moving back and forth under the rotors all it does is change the effective length of the rotor used for compressing vapor. At low capacity only a small percentage of the total rotor length is used, therefore less capacity.
21-01-2010, 02:42 PM #6
Re: slide valve
Please check this book. sorry it is devided into 14 sections because I could not even attach the download link,
21-01-2010, 02:45 PM #7
Re: slide valve
21-01-2010, 02:46 PM #8
Re: slide valve
No 3 and 14
21-01-2010, 02:48 PM #9
Re: slide valve
These are 4 - 5 - 13
21-01-2010, 02:51 PM #10
Re: slide valve
these are 6 and 11
21-01-2010, 02:52 PM #11
Re: slide valve
these are 7 and 8
21-01-2010, 03:00 PM #12
Re: slide valve
the next sections
21-01-2010, 03:02 PM #13
Re: slide valve
this is 10 manual
21-01-2010, 03:04 PM #14
Re: slide valve
the last one 12
21-01-2010, 03:04 PM #15
Re: slide valve
Hope it help you all.
21-01-2010, 03:39 PM #16
Re: slide valve
I think after 15 posts, now I can add the direct download link for the book which is
http://www.pdfgeni.com/book/screw--slide-valve-pdf.html
All the best
25-07-2010, 04:52 PM #17
Re: slide valve
Thanks 4 the info
Put the screwdriver down and step away from the expansion valve !!!! OK Gary i won't touch it unless instructed.
Slide valve wear on Grasso screw after just 54000 Hrs
By Lodiev in forum Technical SpeculationsReplies: 11Last Post: 14-09-2009, 01:21 PM -
calibrating slide valve on rxf control pannel
By marley in forum IndustrialReplies: 5Last Post: 30-08-2009, 06:26 PM -
LEV does not open
By Yuri B. in forum Air ConditioningReplies: 7Last Post: 19-07-2009, 02:37 PM -
FRICK TDSH 233 Slide Valve and guide damaged
By 404cab in forum Industrial CompressorsReplies: 9Last Post: 30-07-2008, 11:24 PM -
Autoloading slide valve for Screw compressor
By screw_geek in forum Industrial CompressorsReplies: 32Last Post: 04-04-2008, 03:47 AM
